Is there a way to control grid intensity (visibility)
As quick background—I use Shapr3D as a tool for creating abstract images of art (photos) for framing and hanging on walls. Given that, you will appreciate that I might have a limited use for a visible grid.
Is it possible to dispense with it at will?
Thanks, Sid
@Sid
Only if your output is suitable for use via Export > Image
Within the latter you can switch off the Grid and other features.
Gelphyn, thanx for explaining this basic matter so succinctly.
Sid
Pleased to learn that it ha helped. Thanks for the feedback.
