Is there any form of flow functionality (a la Rhino)
Hi All,
New iPad user and loving the app so far. I am coming from Rhino and Fusion 360 and I mostly use Rhino for Jewlery design.
I am looking into Shapr as a great on the go solution for when I am doing commissions, being able to design in front of the customer would be a great way to get customers on board, but I need a few essential features to fully commit.
I am trying to figure out how to project repeating patterns along the outside fo a ring. Initially I was attempting to use Boolean operations by extruding a sketch like in th ring tutorial on YouTube, but when I need to have a repeating pattern around the entire circumference I am having issues.
Using project isn’t ideal, and the 2d sketch gets distorted near the edges. I was trying to use the rotate the patterns I want to use around the ring then extrude (is there a circular pattern functionality?).
Is there any plans to introduce some kind of flow functionality like in Rhino, or is there a workaround in the current version?
Thanks!
Thank you!
Hi @HerrChick ,
Did you find someway to do this?
