Ambrus
July 6, 2026, 12:51pm
1
Here are top five challengers after the first week:
1st @Xdrakosha - 21 points
2nd @bidek - 20 points
3rd jhelgert - 19 points
4th @DrKronos - 18 points
5th Mark Watson - 17 points
The leaderboard can change rapidly, speed and consistency makes the most points!
As a reminder:
Complete the challenge → earn 10 completion point
Complete the challenge successfully → earn 6 success points
First 5 people to submit gets → 5-4-3-2-1 points
Stay consistent across the challenge → after 3 participations you get 3 extra points, after all 5 participations you get additional 10 points
Thanks for all the submissions! Stay tuned for the next challenge!
Ambrus
July 6, 2026, 12:54pm
3
If you are interested in the solution for the 1st challenge, you can see it here: Season 1 Challenge #1 is DONE | Parametric Sketching 1/5 - #8 by Dalibor
Will I see my result for challenge #1 even if I didn’t make the top 5?
Hey! I’ve only included the top 5 for the first iteration because all the correct submissions received the same amount of points at this stage. The top 5 is essentially the first 5 submissions received. From the second round on we will share a longer list for the leaderboard as there will be a clearer difference between the points received.
Ambrus
July 13, 2026, 12:47pm
7
Here is the Top 10 (actually 12) after the second challenge:
1st @Xdrakosha - 41 points
2nd @DrKronos - 37 points
2nd Michel Piazzini - 37 points
3rd @schmeeling - 34 points
4th @khang.nguyendinh - 33 points
5th @hatex - 32 points
5th A01425507 - 32 points
6th @bidek - 30 points
7th Levin Haegele - 26 points
8th @Fawksey3D - 20 points
9th jhelgert - 19 points
10th Mark Watson - 17 points
As a reminder:
Solution for 2/5: Season 1 Challenge #2 is DONE | Parametric Sketching 2/5 - #6 by Ambrus
Next Challenge: Season 1 Challenge #3 is live | Parametric Sketching 3/5
Ambrus
July 20, 2026, 2:34pm
8
Here is the Leaderboard after the 3rd challenge:
1st @Xdrakosha - 65 points
2nd @DrKronos - 60 points
3rd Michel Piazzini - 56 points
4th @khang.nguyendinh - 54 points
5th @bidek - 49 points
6th @levin.haegele - 48 points
7th @schmeeling - 47 points
8th @Fawksey3D - 33 points
9th @hatex - 32 points
9th AO1425507 - 32 points
10th Blindfox - 27 points
11th jhelgert - 19 points
12th Mark Watson - 17 points
13th Mojeaux - 16 points
13th @sidang - 16 points
13th @guilhermeschendel - 16 points
13th @drivebydesign - 16 points
13th @marcel-ha - 16 points
14th @Devvon - 10 points
14th Bangying designer - 10 points
14th @Phil - 10 points
Here is the Top 10 (actually 13) after the fourth challenge:
1st @Xdrakosha - 84 points
2nd @DrKronos - 81 points
3d @khang.nguyendinh - 72 points
3d Michel Piazzini - 72 points
4th @schmeeling - 63 points
4th @bidek - 63 points
5th Levin Haegele - 59 points
6th @sidang - 51 points
7th @Fawksey3D - 49 points
8th @hatex - 32 points
8th A01425507 - 32 points
9th Blindfox - 27 points
10th jhelgert - 19 points
As a reminder:
I got a hoodie! I am so pleased!
If it comes I will wear it with pride at the next maker event I go to..
Thanks to staff that supported the challenges. It really helped focus the mind!
Hoodie arrived today! Looks great and good quality. Will post a pic to twitter when I get 5 mins.
Thanks Guys!
