Hello !
I’m trying to make a stamp with my name for my ceramic creations.
But it’s really small. (8mm x 7mm)
Any advice on how to write in a scketch ?
Thank you
Hello !
Thank you
Use the TextToDrawing app on the App Store.
It’s a workaround made by @Yepher
The text tool @Yepher developed works very well, and it’s quick and simple.
However, certain text and the way Shapr works makes it difficult to manipulate some letters.
A more in depth workaround with a lot of possibility for text manipulation is using Illustrator, then exporting the text/shapes as a DXF, and importing them into your project space.
You can use the project tool to scale a sketch on one axis:
2.Put the text on the lower sketch and rotate it vertically to make text shorter in height, and longitudinally to make it narrower in width.
Original text:
Scaled text:
That’s a clever idea. Some people think in 3D better than others.
