How do I add text to my model?
I urgently need to add text function to the model.
Go to the App Store, download the app called TextToDrawing. Pay a few bucks. Then you can import and manipulate all the text you need.
Thanks McD.
There is only one comment about the TextToDrawing , which said the APP cannot be used.
Use Autodesk’s Sketchbook … it’s now free I believe.
Create your text, save your file to your Files. This will save as a .TIFF file
Go to TIFF to DXF (Online & Free) — Convertio
Select to file and convert DXF, bring into shaper and play.
Hope this is of use.
Thanks Lout.
I just used it now. It works fine.
@McD Same. I use texttodrawing pretty regularly.
