Making a sketch on a extruded surface is great, however it seems to convert the surface a plane, which then doesn’t “follow” or stays with the surface if the extrusion is modified. Or is there a different way to achieve this behavior?
Hi, if you double-tap on the face using a finger before sketching on the face, the sketch stays on the face and it allows you to extrude the body from the face.
Hi, the extruded dimension is added or subtracted from the surface’s dimension. I see that the other circle wasn’t extruded at all.
Here’s a short screen recording showing what I mean:
The sketch is not linked to the surface and it’s simply drawn on the surface at that level.
A workround can be to first set the required surface height before making the sketch on the surface.
Hi Morten,
You can use the project tool to make the lines permanent on the surface
//R
That’s what I use 3d modeling/ printing for, trial and errors
Perhaps an other work around would be to extruder the main body downward (minus) and it’s features from there top, that way the surface / plane for the sketch stay together. At least for the first level.
It’s not the lines that I want “locked” it’s the solids. So if I extruder a 5mm deep pocket into the top of a 20mm tall cylinder, I want the pocket to remain 5mm deep when I change the cylinder height to say 15 or 40mm
This looks like a sensible workaround! Thanks!
My (limitied) modeling reference is with Fusion 360, and the ablity to edit parameters of previous actions eg extrusion height is very handy. And then the same with sketchs, eg change a hole or dimension on the schetch and solid model changes.
Seems like I will have too think differently in Shapr3D.
IMO, working in S3D, it is not so much a workaround as a method of achieving an objective.
It can be hard changing to different Software, ‘very handy’ is probably not valid using different Software.
Better to get to grips with the Tools and Features that are available in the new Software?
It is easy to Click on every Icon in every Menu and sub Menu and explore what each one can do.
It is then interesting learning how to apply your new found knowledge to get the results you need.
S3D is capable of most tasks by working with what is available and most often there are several routes to fulfil a task.
S3D offers nimble, but different, ways to alter most things, e.g. going, going, gone:
You are absolutely correct a change of mindset is needed to get the best from S3D.
Fully acknowledge that “workaround” might sound a bit negative, and also it’s easy to use existing experience to look for similar ways too do things. I’m now revisiting S3D after more than 18 months using Fusion as a rookie 3d designer, thus that’s my reference. Direct modeling vs parametric (hopefully correct description) us a bit of a paradigm shift so far. Will now look carefully to find ways to continue to use both into the future, and establish some personal best practices on when to use what application. Thanks for useful tips!
I’m in the same place as you Morten. I love to be able to use the iPad especially because of the pencil.
