Loft Issues
I’m trying to create a 3D model of the Ayn Odin 2 in Shapr3D. I’m using the profile pics off their website.
Here’s what I have so far. I drew a Spline along the right edge of the console as well as, using 3 different planes (on curve on point) to draw a sort of U shape on each, making sure the all have the same amount of points etc and made sure the apex of the curve is touching the intersect point on each plane.
It keeps telling me “the resulting body won’t be valid” but it looks good to me.
What am I doing wrong? It sort of works when I don’t click on the initial spline and I just select the three shapes.
The guide line must be exactly from the first crossection to the last…
I recomend you , make an outline body and use the edges of it as guide. In that case you should not cut the original spline, and easy to change the guide.
