Logical Constraints
One example for a problem which could be solved with logical constraints:
Currently, I’m working a lot with creating fully variable-based generators. Since I design for 3d-printing, my models depend on the size of the printer: if it’s printing area is smaller than the model, I have to print it out in smaller parts.
If I had an option to make some changes appear or disappear or disappear based on a value of a variable, this would speed up my workflow significantly.
The way I expect I to work:
If (variable) > x:
Extrusion 1
Fillet 1
If the case of the constraint is true, the actions in the if-clause get activated in the history. If it’s false, the actions won’t be applied.
A great add-on to variables, and would make their use significantly more efficient.
Sincerely,
