Make surfaces tangental
i have a slot created from a sketch and i have not made the line to arc tangential and so after i extrude the slot i cant put a fillet on the perimeter of the slot as it quite rightly treats the straight edge and arc as separate entities, because they are not tangential, i know i can delete the feature edit the sketch then re extrude again, but just wondered is there a method to make surfaces tangential like there is in sketching.
Thanks for any help
Hi Paul, if the hole is relatively simple, the easies way is to simply delete it (just select all the faces of the hole and hit delete), and then recreate the sketch and extrude it again.
Thanks Istvan
I just wondered if there was a method to makes faces tangential, I use the replace face to make parallel faces planar which works really well
Thanks again
