Moving points at a shape or line
I need to move points of a shape or line independently - in the same plane of course, but I haven’t been able to find out how. Please help.
Maybe you could send a screenshot to make the problem clearer?
You may be falling victim to constraints. For example, if you have a rectangle and are trying to reshape it by moving a corner without any of the other corners moving, a perpendicular constraint on the adjacent lines may be preventing it and you’ll need to remove the constraint.
Hello problem solved thanks for your interest
Yes, my issue was the constraints. Thank you very much.
