I am trying to position one sketch inside another sketch. So for example, sketch1 might be some sort of a rectangle. Then I offset a plane, and start sketch2. Lets say that’s a triangle type shape… I want to tie the triangle to the rectangle with a couple dimensions… but I can’t pick any lines of the rectangle.
So then I project the lines of the rectangle onto the plane I created… Now I can add dimensions between the projected rectangle and the triangle… problem is, instead of the triangle moving, the projected lines of the rectangle are moving… How do I keep the projected lines of the rectangle from moving?
