When you draw a spline on a plane, you are able to move the nodes freely on that plane (ie - x & y axis). Is there a way, however, to move one of the points up and down on the third plane (ie - z axis)? I cannot find a way to do this. I can move the entire sketch in three directions using the move tool, but I am trying to only move one of the node points. How do I do this?
Hi, to see the move/rotate options for all coordinates
Tap on Transform
Tap on Move/Rotate
Tap on the spline to see the arrows.
Let me know if this helps
You can only move sketches by their plane. All points have to be on the same plane, so 3D sketches are not supported.
