Need some quick advice about something I’m having a blind spot about.
When I tap an edge to make a fillet or chamfer the arrow appears and then when I drag it the size tag appears as well but it’s half under and hidden by the arrows.
Some times I would rather just open then size tag and insert the size rather than drag the arrow but often the tag is so far under the arrow that when I try to tap it the app thinks I am happy with the size when in fact I was trying to change it.
Is there a way of getting the tag to default away from the arrows?
Hello John - it is a known issue - thank you for bringing our attention to it. It is indeed frustrating sometimes - I’ll talk with the devs and see if we can come up with a better solution
