Newbie Help with Importing a Sketch
I am trying to create a box with a dsub connector at one end. The box is 100 mm long by 50 mm wide and 30 mm high. I created a 2d sketch, made the walls of the box 3mm thick and extruded the box. So far, easy. I created a 2d sketch of a 9 pin dsub connector in a separate file. I am having trouble importing the dsub file and “pasting” it to the box. I tried the import file command, but it pastes the connector in seemingly random places on the box. Further, when I try to create a cutout for the connector on the box using the extrude command, nothing happens.
Help please with importing and placing the connector and cutting Shapr3d to “cutout” the profile of the connector through the wall of the box
