Notis in drawing module
Hi!
Really miss the ability to write notes and would love for them to be attached to sketch or body.
Kind regards, Patrick
Is this whay you are looking for?
Hi Istvan
No, i want notis in the 3d modul. I want for example write notis as to remember to change a radius on specific part on a boby later on, or write down an idea to solve a problem .
Best regards, Patrick
Hi Patrick,
(there is a reason the S3D-team provided you this template by opening a topic in this category).
Cheers Matt
