I need to draw an oblique cone while keeping the base is circle as it should be but it did not work
Hereās a quick way.
Thanks a lot teacher Tiger
If you can help me find another way because I am working on cone sections
So I need more accurate way especially with the head and axis of the cones
The Loft tool might be better, if you need more accuracy.
Hereās a more accurate method. Height is 10.01mm, bottom is 5mm radius. Angle to make oblique is 15°. Height of 7.5mm is arbritrary to get the 2.0096mm offset from the 15° angle.
Note: there is an anomaly if I make the sketch height 10mm and try to extend the truncated cone to 10mm. Some sort of internal math error. 10.01mm initial sketch height works when I extend to the physical 10mm height. Hope this helps.
Thank you very much teacher
You save my timeš
