Hi, I’m trying to draw that shape and there is always an overlap with the taper version. The angles are 15 deg since there is 12 faces. I use the miror function to add faces.
Welcome to the forum.
This might be an easier way.
Thank you but I need it to be taper. Conical. The base is 20’’ wide and the top is 10’’.
My example shows the twelve sided body tapered at 10°.
Set the extrude draft angle accordingly based on the overall height of your shape.
Let me know if you need help with this.
Thank you so much
Thank you I did not notice the taper
Hi, I can I ask you how the «loft » part is made. I’m trying to draw lines and it does not work. Is there a function for that? Sorry, I’m not very experimented with sketching on Shapr3d….
Just found out what it is on the french version. Thank you again!
