Overhang Design / Advice / Thoughts - Unistrut Roller
Im exploring a railed mount for my battery trimmer / router.
Im trying to avoid purchasing anything and working with what I have. Lots of unistrut.
Rather than buy linear rails looking to go for a wheeled mount either on the top of the section (as shown) or perhaps in between.
Want make composite out of 95A TPU and a PLA or PETG Core.
First outline. My thoughts immediately go to the printability of the overhang.
On that note - Re - the current obsession with tool changers. Has this come at the expense of progressing other technological solutions such as improved overhang, part strength - other structurally important progressions.
Went with TPU with PLA support in the end.
Consider a few options:
  1. Print in two halves for the core and super glue together. Make a TPU ring to slide onto the composite.
  2. Use the flat center to roll on instead of the edges. It may not matter in this particular use case but using the flat will reduce the outward force, reduce friction, and lengthen the part life.
  3. Turn the strut upside down and make an H wheel that rolls on the flat and is constrained by the left and right flats. That would give you the widest surface area for the wheel but you’d have to be careful about the material hardness against the vertical walls and alignment of the two rails (assuming there are two in your design). It will bind unless you have the optimal geometry on the chamfers.
Thanks @shaprvision
Very interesting options.
Am I getting it here?
I’d prefer the middle one if you are using a single strut. Binding may be an issue but not as much as the one on the right where the vertical down force will push the strut outward into the dumbell.
If you are using 2 parallel struts, I should have said that upside struts with train wheel geometry for the wheels would be the best bet.
