Overlapping of Lines
Hello Everyone,
When I am sketching of lines in horizontal and vertical they are overlapping. I dont want the lines to overlap, when I am pulling the surface it is breaking or they are mixing up. where ever there is intersection lines I need little bit of bend based on the thick ness of bottom or top Line.
I am trying to achieve mesh design, below is the picture for reference.
Regards
VK
Here is a method.
Wow…
Thank you for information but I am expecting the gap less and I dont want that joint. Let me try based on your solution.
This is the outpout which I am expecting.
Some one can help me with this design please.
I tried but I am not successful
Regards
Vithal
You should first draw a zig-zag line, then use the sweep command with a small rectangle and the pattern tool.
