Hey community,
I need your help here with this project. I could do without it probably since the client is going to get the idea anyway with the other panels done but I feel like it’s not the first time I’m trying to do something like this.
So what I’m doing as you can see on the video is incorporate the corrugated at the middle of my frames and subtract a bunch. Then I trace my waves and substrat that plane.
I kind of did the same with the mesh.
My problem is where the 2 closest panels from the gate are. As you can see it has 2 kinks. I managed to take of a fine stripe of .01 to “cut” the corrugated and rotate it at the cut and do it for both kink. I’m having trouble with the mesh. Is there a better way to do it?
Also on top of the corrugated there is a 1” flat bar following the waves. No problem for the flat panel but shit start hitting the fan at the kinks.
I hope I make sense. Thanks.
