I made a rounded rectangle (RoundRect) by :
- create a Rectangle
- create a Circle
- drag the circle so it touches the Rectangle corner
- use the Trim tool to delete segments of the Rectangle and Circle
- set the circle Radius to a variable
it works nicely at my initial 5mm circle radius:
However, if I change the radius, say to 10mm, the two points of the arc stay fixed, so the end result is not what I want:
The problem appears to be that I locked the wrong points – if the radius changes, the edges of the Rectangle must logically change lengths too.
Is there a way to set this up so the radius can be changed while keeping the proper geometry?
