I created a New Plane using the Mid-Plane option. I tried to rename it to Plane -4 but only garbage characters showed up. I cannot change these.
s3d file encl.
Thanks,
Handle 2.shapr (396 KB)
s3d file encl.
Thanks,
Is this still happening, with the latest version? We have fixed a similar issue in 3.0.6
Am using the latest; 3.0.6.
Thanks,
Sometimes the characters are not garbage! Here I typed ‘Front’ and got ‘process’? I don’t believe that I use this word anywhere?
Can you check this with the last update (3.0.7)?
DLd new version. Loaded WS, still displayed process but I was able to rename to Front.
Will advise if I see this again…
Thanks,
