Please help reproduce this
Hello.
I’m a newbie of shapr3d, usually I use fusion 360.
Now I need to reproduce this: it’s a pear base with decentered cone.
The problem is to reproduce the pear shape.
Tried the eclipse, tried the circle with eclipse outside, but nothing.
Does anyone can help me?!
Thanks a lot
Take a look at 1 minute in the video
Thank you :pray:
But the shape is circular, i need to create one like pear…
From the uploaded image I can not really picture what the pear-shaped base looks like - can you try using extrude as shown in the video below and then try out different draft angles to get the shape you want. Since it’s base you might need to push downwards on the closed sketch. Let me know if this helps.
Like that?
Made a video on how to create the “pear shape” and how you can move the circular edge on top. Hope this helps: https://youtu.be/z9ASTvTJh3o
Thanks a lot for all replays and the help :pray:
I have to reproduce this piece
It’s the dock for the antenna in the roof of the car
:disappointed::disappointed::disappointed: can’t find a way to do it
Arrived at this point, but I don’t know how to remove the square parts that came out from the cylinder…
https://drive.google.com/file/d/18lG2PguRMOtUqIa81ijFZai6nfrYWCMs/view?usp=drivesdk
Decrease the height of your box to not intersect with the cylinder and then choose the top face of the box and replace that face with the inner face of the cylinder.
But if I decrease the inside box, then the walls don’t touch the cylinder…
Use the Replace face command to align the rectangle perfectly to the inside of the cone (after the command you can Union them if you want)
Here is a coarse video on how to do it:
Here is the support article for Replace Face: https://support.shapr3d.com/hc/en-us/articles/115003134433-Replace-face
That’s why I’m saying to use replace face afterwards…
Did it, thank you! :pray:
