You can’t offset edges, only faces. You can move them with the Move tool though. If all you’re wanting to do is increase the radius of the curve, select the curved face and the Offset tool will select automatically.
To offset the edge is only available on sketch.
You can still offset the face once it is a body.
By moving it can I get the same effect as offsetting it?
