Maybe I am missing something. How can I print directly from the app to my network printers. At the moment I used a screen capture app to select the view I want, the print out the resultant png file. This works well. Is there an easier way to do this from within the Shapr3D app?
Do you want to print a drawing?
If sending views to portray the design, I use to use the Image Capture within Shapr3D. But NOW, I use the new web viewer to do this. It allows the customer to view the item in every imageable angle.
Either you can create a drawing, export it to pdf and print it, or you can use the image export feature and print the image. Or just like @McD said, you can use the Webviewer to share the design with a single click using a private link.
Excellent. Many thanks for making my life a little easier. Cheers
Thanks. I have mastered using the web viewer. This is a perfect collaboration tool.
Thomas Dunlap
ASTRO Systems, Inc.
7979 Old Georgetown Rd
Suite 650
Bethesda, MD 20814
301.913.2800 Press 2
