Problem with entering a size directly
Hello All. Spontaneously in the beta version it is no longer possible to enter a size while creating a line or circle for example.
I have already closed the program once, created a new project, but this does not solve the problem. In the installed non-beta version this problem is not present.
Are there more people experiencing this problem? Possibly a suggestion for a solution?
specs MacBook Pro
16-inch, 2021
Apple M1 Pro
16 GB
macOS Sonoma 14.4.1
Herewith two screenshots, while pulling the line
beta version 5.590.0 (6712)
non-beta version ( 5.580.0 (6676)
Press tab key and then enter the value.
Good morning Alex @Xdrakosha. Thank you for your quick response. This morning I restarted the program and got a notification that a new version was available.
From 5.590.0 (6712) → 5.590.0 (6719)
Problem solved :slight_smile:
Scherm­afbeelding 2024-04-04 om 06.54.38
