Problem with the items dock: it changed position on the screen
Hi!
I’m right handed and i used the item window docked to the left of the screen.
When trying to move a body to an other folder today, the window changed its position to dock itself in the right side of the screen. I can’t get it to go back to the left side of the screen.
I’ve tried anything i’ve thought about.
Oddly enough, the modal behavior is normal. See picture below.
Is this a bug? Or am i enable to use it correctly? Any help would be much appreciated.
IMG_1944
Hi -
yes it is not one of the most obvious interactions, please swipe left on the header. See Vid below https://us1.discourse-cdn.com/flex002/uploads/shapr3d/original/2X/1/121608cc6724ac165256c1c1dffceab72b071a94.MOV
Thanks! It’s not obvious, but it works!
Maybe you should document it on the items’ section of your manual.
Cheers.
Will do :slight_smile:
