I’ve created a model and there are some lines that I guess have appeared when extruding parts of the walls, there minor but are throwing off the 3D print and hitting the delete key on them don’t remove them.
have you tried replace face ? The lines suggest that the faces are not parallel or not at the same height.
Thankyou, this has worked.
