The problem that this feature will solve: Make simple adjustments to imported geometry in the source model
Being able to revisit the Import command in the history tree and re-import a step or .shapr model would assist in modelling assemblies because adjustments to imported geometry could be done in the source model. Re-selecting the source file in the original import would then update that imported geometry in the assembly.
Brief description of the outcomes that you expect from this feature: Faster design iteration of variations of assemblies based on common components.
This feature should allow designers to edit and create multiple similar assemblies based on parts that are design separately
this is again a quality of life issue. doing small modifications to imported geometry in the history of the assembly can lead to unpredictable results. Especially when the align function is used subsequent to the import.
