I frequently create objects that I would like to re-use in other designs. For instance, I might create a gear or a bolt that I will use in subsequent designs. I like to keep the ‘master copy’ in a separate Shapr3D file, and then import the design into the new file. However, to do this requires exporting the object and then importing into the new Shapr3D file, which is cumbersome.
I would like to make it simpler to import designs stored within Shapr3D. I would be content if you added an option to the import dialog box for ‘Import Shapr3D design’ that then allows a user to select from the same designs available in the ‘Designs page’.
This is not a blocker, it is just a pain to export and import today. This feature would speed up my workflow and enable me to keep my master designs better organized.
