Remove section of thread
How do I remove a section of the thread which will be in the middle of it approximately.
thanks in advance
I want to create like a dip or pocket in the middle of the thread
Use the top surface to create a plane to sketch the cut you want out of the thread.
So I extrude through the thread? With a shape to create the cut away? It will have to be a partial intrusion in to the thread as I only want it on the underside. I am not entirely clear on
What to do but thanks for the pointer
I Just
Realised this will also be on to a curved surface so will be more difficult than a
2 D sketch
Hint: You can project the curve to the drawing plane.
I think this is what you want to do. I essentially did the same thing as @Oregonerd. The only difference is, I kept the plane against the top surface of the cylinder. The video shows both removing a section and removing only the underside of the thread. Sorry for the speed
Yes that second one is what I trying was to do
Thanks to both of you
