Is there an easy way to rotate an object so that its vertical? Or do I have to measure the angle its at and then rotate it? I have a plate at an angle I need to rotate it so when I put it in the 2D drawing it shows the actual size of the plate. If I don’t rotate it then it just shows the plate at the same angle thats in the model.
Create a dummy vertical block. Use the Align tool to re-orient the plate to the vertical surface of the block. Then delete the block.
Great idea. That didn’t even cross my mind. I appreciate it.
