I made a model plane mounted at an angle on a stand. As I modeled the plane first, everything on the plane matches the x-y-z axis so the plane comes out perfect when I make a 2D drawing. The stand on the other hand is at 20 degrees to the plane and when I try to make a drawing of it, it comes out in “3D”. Is there a way to make a drawing normal to a face?
Thank you in advance.
