If the center point remains unchanged, there is no problem with the rotation. However, if I change the center point, the rotation has issues. Why is this the case?
Hello,
What issues are you talking about?
You have Section View turned on. Turn it off and you should see the expected behavior.
Where to turn off the Section View?
Hello, its on the bottom of the tool bar (left side)
I got it!! Thanks!!
I got it!! Thanks~
