Rotation/orientation view
Hello,
Still LOVE, LOVE, LOVE Shapr3D on my iPad M2 Pro. Once I extrude and create a model and before I export said model I want to rotate said model to the correct printing/slicing orientation. First, is there an easy way to perform this simple function. I have tried to click on a plane view but the only way to rotate the object is to move the object in 3D space first and use the arrows. This is just to cumbersome to use. There has go to be an easier way to rotate or “Snap To” a plane.
Thank You
Right now I just used the Align tool to create a sketch plan on a different plane. Then by using the Align tool this makes the object switch planes. But is there an even easier way?
Have you tried the Translate tool? That may be what you are looking for.
