while turning a thread with the revolve tool, you can not enter even numbers at height (angle and height). as it is only possible with odd numbers (with decimals), the thread to the counterpart is always higher around the decimal point and of course, now it has a distance between the thread windings. Previously it was possible to work with even values. Since I already did half of the work, the counterpart should now have the same values to match and screw together.
@DSGroup
Did you resolve this problem?
I am embarking on an exercise better understand Thread forming in Shapr3D, and found your post while trawling the Forum for info.
