I have a .x_t file (attached below) of a simple unit cylinder created via the Parasolid C API which was (intentionally) created with PK_SESSION_set_precision(1e-5) . It seems that Shapr3D can’t load this file? I get a “Import failed. Your source file couldn’t be loaded because it’s damaged.” Just changing the precision back to the default 1e-8 before creating the cylinder and saving makes it work.
I’m just wondering if this is a known issue and/or if there’s any possible workarounds that don’t involve me generating a higher-precision body/file? (which would be kind of complicated in my real non-toy-cylinder case)
**ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz**************************
**PARASOLID !"#$%&'()*+,-./:;<=>?@[\]^_`{|}~0123456789**************************
**PART1;MC=x86_64/znver4;MC_MODEL=512x(AMD^_EPYC^_9754^_128-Core^_Processor)@150
0MHz;MC_ID=thebeast;OS=Linux;OS_RELEASE=6.8.0-87-generic;FRU=Parasolid.jl;APPL=u
nknown;SITE=Warren,^_MI,^_USA;USER=ubuntu;FORMAT=text;GUISE=transmitckernel;KEY=
/mnt/nfs/nomad/dev/marius/cyl_1e5;FILE=/mnt/nfs/nomad/dev/marius/cyl_1e5.x_t;DAT
E=27-jan-2026;
**PART2;SCH=SCH_3700150_36001;USFLD_SIZE=0;
**PART3;
**END_OF_HEADER*****************************************************************
T51 : TRANSMIT FILE created by modeller version 370015023 SCH_3700150_36001_1300
6231 0 12 36 CCCI7 lattice222 0 CCCI4 mesh1006 0 I8 polyline1008 0 CCCCCCCDI5 ow
ner1040 0 CCCI16 boundary_lattice222 0 CCCI13 boundary_mesh1006 0 I17 boundary_p
olyline1008 0 CCCA16 index_map_offset0 0 1 dA9 index_map82 0 A17 node_id_index_m
ap82 0 A20 schema_embedding_map82 0 A5 child12 0 A14 lowest_node_id0 0 1 dA16 me
sh_offset_data206 0 Z1 18 0 0 0 0 0 0 0 0 0 1e6 1e-5 0 2 0 1 0 1 1 3 0 4 5 0 0 0
6 7 0 0 0 0 0 0 0 0 13 255 3 3 0 1 0 8 0 0 9 0 51 255 4 18 0 10 11 0 0 +0 0 -.5
0 0 1 1 -.847851691824494 .530233447332724 0 31 255 5 16 0 7 12 0 0 +0 0 .5 0 0
-1 -.847851691824494 .530233447332724 0 1 19 9 CCCCCCI5 frame230 0 CA5 owner12
0 Z6 1 0 1 9 0 13 0 V0 16 255 7 12 0 ?14 0 15 5 0 0 1 17 255 14 0 16 14 14 0 17
7 0 0 +16 15 6 0 ?18 7 0 12 0 0 1 17 18 0 19 18 18 0 20 15 0 0 +31 12 10 0 15 0
5 0 +0 0 -.5 0 0 1 -.847851691824494 .530233447332724 0 1 15 255 19 7 0 18 10 0
17 20 0 21 20 20 0 18 15 0 0 -15 21 8 0 20 22 0 14 255 22 9 0 ?10 8 21 3 23 +0
0 10 8 13 14 10 2 0 ?0 22 16 3 4 +0 0 0 22 13 14 8 15 0 ?22 0 24 3 11 +0 0 22 0
13 50 255 23 11 0 22 0 11 0 +0 0 -.5 0 0 -1 -1 0 0 13 13 4 0 0 0 0 0 0 6 8 50 1
1 17 0 8 23 4 0 +0 0 .5 0 0 1 1 0 0 15 24 14 0 17 8 0 17 17 0 24 17 17 0 14 7 0
0 -15 16 13 0 14 10 19 19 9 5 0 1 0 6 3 0 S0 1 0
