i am currently working on a sculpture project and need to create accurate cross-sections for stone cutting. I am using the Sharp3D program, and I would like to ask if the cross-sections generated by the software are done correctly for this type of project. Additionally, could you please advise on how to ensure that the cross-sections are precise and suitable for my needs?
I want to make sure that the sections I create will work perfectly for the execution of the sculpture in stone
Hello, shapr3d is cad program which makes it accurate as possible. But it really departs what is your needs of your project.
Can you provide some screenshots of what you need or how you want to cut that object?
Ok I probably understand. So you need to create a new drawing (it is only in full version)
here i found Shaper3D original video about crosssection
and here another
you can also create custom view so it allows you to make cross-section from different angle.
I hope it is what you want
