I press and hold shift and try to select two objects it doesnt work.
Hello! Thanks for reporting this case, but we would need some more information to be able to investigate this issue. Please share the following with us in the thread or in a support ticket:
- The version of Shapr3D you are using
- The detailed hardware specs of the device you are using
- A short screen recording of the issue with showing the keyboard presses turned on (you can find the option in the Settings of Shapr3D)
Thanks in advance
The version of Shapr3D you are using (5.381.5210.0 #f3afec7e)
The detailed hardware specs of the device you are using (ntel(R) Core™ i5-8210Y CPU @ 1.60GHz 1.60 GHz, 8.00 GB (7.87 GB usable), 64 bit)
