When I isolate a body, why the sketch also appear? I already hide the sketch……
I don’t know if it’s a feature or a bug, but it does have advantages in history-based modeling. If you want to change a dimension that was set up in a sketch while the body is isolated from the other bodies, you can’t do it if the sketch doesn’t appear.
@Gusriwandi yes it can be annoying and so we will disable this behavior in one of the coming releases.
@TheBum you are also right, accessing driving sketches when looking at certain bodies in isolation is important. At first with the above change it will be harder (they have to be included in the Isolation set as well), however we will enable interacting with driving sketches down the road (as it is a bigger investment in how we control visibility).
