Hey there! I was wondering if the app is able to generate sketches from objects.
I made an object using sketches and then I made some alterations to the object. The sketch obviously doesn’t reflect the new dimensions of the object. So how do I get the new measurements in the sketch without having to update it manually?
I feel shapr3D should be able to read the new object and make the new sketch.
Hide the original sketch plane, and create a new plane (offset it some amount) then use the Project tool to project the shape of the body onto that plane.
