i want to fill the parallelogram between the equal sided triangles.
I create a plane with three points to sketch on it. But now i cannot snap to the triangles corners!
Hi, if I understand your request, you will like to replicate the sketch on the other side.
How about you try using the Mirror feature from the Transform menu using the edge by the side you want the replica as the mirroring axis:
From what I understand, you will need create the sketch with matching dimensions with the face you will snap it to
Hide the plane
Then use the Transform move/rotate feature to reposition the sketch to snap to the corners of the triangles
I tried to do so! But snapping doesn’t work!
Please send the workspace to support@shapr3d.com. We will look into the issue and then get back to you as soon as possible
Thanks,
you have mail.
Did you ever get an answer on this? I have a similar problem of creating a working plane using the edges of faces but when I sketch on the new plane it wont snap to the edges or any vertices on the edges. Very odd.
Hi! To snap sketches to existing elements, you need to project the edges/faces to the currently used plane. The projected elements will be automatically locked, they will not be moved after applying constraints on them.
