Spar3D in Machine Tool Design
Are there any machine tool design engineers in the forum? Kindly share your experiences in using Shapr3D for machine tool design. Thanks.
You can use the object you’ve created in several ways. You can send the STL file to an EDM fabricator. They can create the electrode to the shape of your object for die casting.
You can export your object to Aspire, or other CNC software, to use within a larger project.
