I can see that this question has been asked before but I haven’t seen it answered. Is there any way to make dimensional measurements for splines in 2D Drawings? Here is the part that I am working on and how the splines are included.
Thanks!
That would be the length of the spline.
If you are just looking for horizontal or vertical length you can manually use construction lines like a ruler to measure.
also if you select the end points you will get measurements.
