I’m looking for a solution for splitting body created in Shap3r by using mesh body as splitting tool. Below you can find screenshot that will explain where and how I’d like to split body. If there is no tool for that do you have any other suggestions how I can achieve such a split?
Hi
Shapr will split a scanned surface (STL).
Be patient the geometry is slow to process.
Decide where you want to split the body, add a plane, then move it to that position.
Now select the surface body, select ‘Split body’, and select the plane.
Click on the Tick to finish.
The only way I can get there in Shapr is to do the following, but it is labour intensive.
Position a plane where you want to generate the profile cut.
Cut the STL surface using ‘Split body’
Now generate a sketch on that plane.
Trace along the cut edge of the surface with the 2d line tools (Line, spline, etc).
Now use this line as that side of a closed shape (like the panel you want to make).
Once you have a closed shape, you can extrude.
It took me about 10mins to trace along the cut edge carefully and generate the new body.
It is a shame, the fact that shapr can cut the 3d mesh surface and end up with a clean line means that it should be able to generate a line on that plane.
Thanks, that’s what I was doing so far. When it comes to more complicated shapes it is a bit of work but it does the job. Thank you very much for trying to find better solution
The 12 mm body is solid body created in Shap3r. I don’t want to create solid body from STL. All I want to do, is to use STL as cutting/splitting tool ald split body I created.
As far as I know I have to do it manually. Thank you for help
