Hello!
I’m turning to you again!
Is there a way to stretch a 3mm thick curved sheet/test and see its entire perimeter from a top view?
A curved body needs to be covered with a sheet and manufactured. The covering is already in order in the plan, we should somehow see the perimeter that we would cut out with a laser and then bend onto the body.
Is there a way to do this stretching/unfolding?
Thank you very much in advance for your help!
