First I’m sorry for the sideways image I tried taking the photo in both directions.I’m trying to make a jig for a set of A-arms the scan is where said a-arms sits. I’m struggling to make the planes to begin sketching off of the scan. The first two larger pockets sit on the same level plane. While the smaller pocket is pitched at a slight (15-20) degrees. How would I go about making planes level to the pockets I was thinking about using the studs as points to create the plane yet on shaper I can build directly off the mesh scan
