Tapered Sides
I’m designing a cup holder for a wheel chair.
I’m wondering how to create tapers.
I need two different tapers.
  1. I’m creating a ring for a cup to slide into. It needs a slightly tapered inner surface.
  2. I’m creating a dovetail to slide the rings connection into. How do I create the two tapered parts of the dovetail.
Thanks.
Hi David,
Maybe I can help you out:
The last step shows how to make the dovetail conical, so it can clamp itself into the groove.
HTH
Cheers Matt
Thanks. I got the dovetail portion done, but I’m not sure about the angled ring.
I basically have a 3d ring drawn but want to angle the inner wall slightly so a cup will pressure fit. Not sure how to accomplish that.
Here’s what I have.
You can subtract the cup from the cup holder or ring.
Sketch the section of the angeled ring and rotate it with revolve around the axis.
