Terrible performances lately
I’ve been encountering a recurring issue, particularly with sketches. After isolating an element and starting a sketch, the performance takes a nosedive. Sometimes, it’s extremely challenging to precisely target a point.
I suspect this slowdown is due to the size of my assembly, which currently stands at around 2500. However, I don’t recall experiencing such significant sluggishness before the latest big update.
What are my options for addressing this issue? Please, I’m in desperate need of a solution.
Totally agree
Currently none. There’s been a lot of back and forth about performance. A lot of denial, gaslighting, and frustration. The answer is to wait for the new release which removes the HBPM with collapse history (has to be done continuously, not a toggle) and hopefully improves the performance issues.
Same issue for me but it’s anytime I sketch. Not just when in isolation mode.
I isolate every time, but same problem if I do not.
Performance issues never seen before creeping up with ver Version 5.603.0 (6875) on a Mac M2 and iPad Pro (2018), especially related to:
(1) realtime movement of imported objects STL files
(2) opening projects stall and spin on “loading” for upwards of 5 minutes, even empty projects
I love this software so much it feels a bit painful to complain here…but this worries me.
Can you share a problematic design?
This is a known issue, we are working on improving it.
(1) Happens with most everything now (ie. drawing a line it will freeze up). After testing, it may be project specific.
(2) Some projects are almost entirely unusable at the moment. I’m going to list a few things that seems suspicious and/or recently changed, if useful:
[a] History functionality: history + my use of large STL files. Shapr3d is the ONLY software that lets me do anything remotely close to what I want to do with scan data on an iPad. It definitely stretched the limits but remained bulletproof with nothing changing in my workflow.
[b] 2018 iPad on OS 17.5 (will iPad M4 improve any of this?)
[c]. Latest version of Shapr3d
