Hi guys, can anyone advise how can I add text along a path? Eg. on a circle I need the text to follow the perimeter of the circle.
Thank you.
Thank you.
Hi. This option of adding text on the curve is not possible in Shapr3D right now. I hope Shapr3D add this feature in soon because sometimes I need add text on the curve too. So we will see in the future.
Hi @Xdrakosha, How do I do the first option? Does it have to be in the middle of the line? Can I do the Text above/on the circle? Thank you in advance!!
I’ve used move tool and position letters on their places. There is no automatic tool for that. But everything can be positioned quite precisely manually.
Only you decide where it will be.
@Xdrakosha thank you!
You’re welcome.
If you’ll struggle to hard with that I will make a video how that can be done.
